Caporegime
- 11 Mar 2005
- Leafy Cheshire
Access should be ok too, the transverse 1.8t is easy enough to remove the sump off, the Longitudinal one you need to start moving sub frames out the way.
I got VW to replace the pickup and the pipe, the part is cheap so you might aswell change it rather than clean.
