clever - had you also avoided any installation charge ?Just rang sky to cancel....not even activated yet
looks like emby will have a subscription charge ($50/pa) as does hdhomerun - no ?Just need a nice live TV front end (which hopefully emby will be)
Nope using an old wintv card in a spare pc.looks like emby will have a subscription charge ($50/pa) as does hdhomerun - no ?
(presumably your dvbt card attaches to ps4 which will serve emby?)
Hdhomerun and channels app works great much better than plex or emby, have to pay for dvr service but well worth it
ok - because the homerun will attach to usb on a shield (and maybe ps4) afaik ... potentially reducing electricity.Nope using an old wintv card in a spare pc.
Hdhomerun doesn't have the wide app support in the same way that Plex/emby are available on Roku/android/PS4 etc. So if you get a hdhomerun you still need a Plex/emby server to get it into e.g. a Roku stick for a single front end for "wife approval factor"
You can use channels app instead of plex / emby on hdhome
Like I posted you can use the channels app, available on android, Apple TV, iOS and fire tv, with a hdhomerun tuner works better than plex or emby but dvr is a subscription based server, its the best tv app in my opinion and the support is great
you mean it is really cancelled and the price is now zeroDon’t think I can get it any lower....
@Armageus many low bit rate SD channels aren’t controlled by Sky so they have limited push to improve these. Also many older programs would look worse with higher bit Rates!
It would involve actually changing channels on the fly. Each local station is broadcast on its own transponder and frequency.But where there is a hd (or 4k) version of a channel available, couldn't it default to that. With BBC hd it could just fallback to the SD channel for local broadcasts and then back again for everything else.
Anyways haven't bothered trying Emby as found out it needs a separate EPG unlike Plex - so more cost (e.g. schedules direct etc) and another separate service (and more to go wrong)
humax freeview pvrs, will propose hd version of channel (if it exists) when you switch channel or schedule a recording (i assume my old foxsat would do too)But where there is a hd (or 4k) version of a channel available, couldn't it
