Malt_Vinegar said:Have you ever seen the video of the katana blade cutting a bullet?
Lord Pablo said:From what i have read in books, the swords made for Samurai were tested thoroughly by the blacksmith making them.
They would either test them on corpses from recent battles, or, more likely then not, straw dummies soaked in water.
They did a variety of testing "cuts" involving such ones as arms, legs, decapitation, and the final one being a slice from shoulder to oppposite waist/midriff.
The tang of the sword would be inscirbed with the tests it completed.
Katana's (for the majority, but also the Wakazachi (sp) and Tanto) were razor sharp, and are designed in such a way they work in a slicing motion.
Also, from looking in my book, Flashing Steel (a book all about Eishin-Ryu Swordsmanship) if you failed to kill your opponent in the proposed single move, you could counter-attack/defend by slicing off a hand or even whole arm.
fatiain said:I think left to right or right to left would be pushing it a bit too.
Whitewater said:It would depend a lot on technique. I'm not sure it's possible but if it is you have to ask yourself, have you created two seperate humans or simply cut a single human into two halves![]()
) to withstand compressian vertically. it's unlikely to be anywhere near as strong laterally and the blade wouldn't be offering compression anyway.NathanE said:A proper Samurai sword and a proper Samurai to go with it and IMO yes it is possible to slice somebody in half from side to side. I think shoulder to groin is less likely though.
A "proper" Samurai though wouldn't do it I don't think as he'd consider it a waste of energy and a potential risk to his sword. Much easier to just slit their throat or stab them in the heart![]()
dmpoole said:You would create half twins with different personalities.
One would be left handed and the other right handed.
