Smart Casual
A man would not actually have shoes like this would he ?
I remember when i saw a grammar nazi who didn't know grammar, his name was spitzoid and i busted him on 18th Jun 2009, 12:31 AM ;)
Enlighten me to my mistakes and I'll be happy to try and improve.
P.S. You really should have capitaliZed those i's in your mini-rant if you wanted to drive the point home, but whatever......
nex20 said he worked There, there being a place it is the correct word, their would imply someone and doesn't make sense in the context it was used in.
Some of there stuff is. I worked there a few years back and some of the clothes cried asbo tbh
Read the first/1st bit.
Therefore, you're/your wrong/rong.
n00b
*waits for apology*
Ah a few boos from the crowd
So let's see so far the loafers are for a...
**** and Wallet ******** (i dont even know what fills the stars after wallet)
Someone's Nan
A Gay guy
looooool very harsh
Well I definitely didn't advocate the white ones, I think they look pretty bad too. But the Brown ones are top notch in my opinion and it's not because they're LV. I couldn't care less about the brand. In person however, and you should see them in person before making a judgement, they are simply just an excellent pair of loafers. Calf leather, extremely soft yet sturdy and have the appearance of swede and maintain their frame so they don't distort when you wear them, very deep rich brown, they're incredibly comfortable and they're beautifully designed with a very cute metal finish to the front braids. What more could you want? But I guess it's a taste thing.
Go to Massimo Dutti or Zara and pick up a nice pair of Corderoys in Navy Blue or Beige. Massimo also does some nice shirts if you're a slim fit so pick up some good ones there. Avoid Loud/Noisy patterns, the simpler the shirt the better. Elegant, Sophisticated colours and classics, nothing shiny nothing patterned. Try to avoid shirts with plackets they look cheap and rubbish
Colours to look for if you're going with navy blue trousers are light to medium blues and whites. If you're going with beige, all blues light or dark, classic black or whites but my preference is blues as it's by far the most elegant combination and looks very sharp/expensive
Get an elegant brown belt, the more understated the better. Dunhill does very good ones but they're a bit pricey.
For shoes there is no other choice then louis vuitton monza loafers in my opinion. these things ooze class and elegance. Pick up a pair in brown or dark brown, they will go with either navy or beige trousers and you'll have the right belt already from the step above.
These are the ones I'm talking about, they'll set you back around 500 pounds but well worth every penny.
images
