Caporegime
- 21 Jun 2006
vmware wont install on vista 64 bit, tried using all sorts of different compatibility modes got the same error on each one, that the installer was interrupted during installation
SiriusB said:@shadow - Without wanting to go off at a tangent, is there any particular reason why you failed to get this going shadow?
shadowscotland said:If I knew that I be a happy man - I'm guessing it's all to do with the office proxy server and network (as I set my home machine up here at work, to use the office BB connection)
Can only run ubuntu off cd at home, can't access internet via firefox at work
Berserker said:Just for fun, I'm running 64-bit Linux on 32-bit Linux.![]()
Might be a pain to upgrade?shadowscotland said:Why not just go native and mimimise the proformance hit.
This is FAH ("Folding At Home") installation script (ver. 5.3).
To get to know more about FAH, go to http://folding.stanford.edu.
Testing the availability of external utils...
...done.
Using flags:
nofetch: false nomd5: false copycfg: false
keepcfg: false norun: false no3rd: false
freebsd: false wine: false skip3rd: false
fcliA: false fcliB: true nodocs: false
get3rd: false setid: false keepid: false
auto: false screen: false noscreen: true
samba: false macosx: false linux: true
setcfg: false gentoo: false openbsd: false
smp: false
Setting up FAH client(s) for 2 processor(s).
---Documentation---
Downloading finstall FAQ:
11:33:42 (197.71 MB/s) - `FAHLinux.txt' saved [39183/39183]
[B]
Do You want to read finstall FAQ (y/n)?: N[/B]
Creating /home/michael/foldingathome/folding...
.../home/michael/foldingathome/folding created.
MD5SUM value of downloaded FAH504-Linux.exe:
1316853b439d25a4a56adf82fcd953db FAH504-Linux.exe
[B]Is this the correct MD5SUM value of FAH504-Linux.exe (y/n)?: Y[/B]
---3rd party FAH utilities---
Some 3rd party FAH utilities can be used by folding script:
1. Dick Howell's 'qd' and 'fpd' (http://linuxminded.xs4all.nl/?target=software-qd-tools.plc)
[B]Do You want to use any of these 3rd party FAH utilities (y/n)?: N[/B]
FAH 4.00 will check the MachineID value and terminate itself if it does find
another FAH client running with the same MachineID.
To overcome this, You either must start the client(s) twice or install every client
with unique MachineID value.
Do You want to use automatic MachineID changing (y/n)?:
