- 2 Aug 2005
- Cleveland, Ohio, USA
Rats! I'm always screwing that up. I've done it on here once or twice before.
Well enable it and see how it goes. Once it's done and you've rebooted open up a terminal and type glxinfo. Look for the bit that mentions Direct Rendering. You want this to say yes. If it does, enter glxgears to test 3D rendering. It should look nice and smooth, not like a slide show.
EDIT: Technically speaking rebooting is not necessary, but it's probably easier for you to do that rather than manually load the kernel module.
susan@susans-desktop:~$ glxinfo
name of display: :0.0
display: :0 screen: 0
direct rendering: Yes
server glx vendor string: SGI
server glx version string: 1.2
server glx extensions:
GLX_ARB_multisample, GLX_EXT_visual_info, GLX_EXT_visual_rating,
GLX_EXT_import_context, GLX_EXT_texture_from_pixmap, GLX_OML_swap_method,
GLX_SGI_make_current_read, GLX_SGIS_multisample, GLX_SGIX_hyperpipe,
GLX_SGIX_swap_barrier, GLX_SGIX_fbconfig, GLX_MESA_copy_sub_buffer
client glx vendor string: ATI
client glx version string: 1.3
client glx extensions:
GLX_EXT_visual_info, GLX_EXT_visual_rating, GLX_EXT_import_context,
GLX_ARB_get_proc_address, GLX_SGI_video_sync, GLX_ARB_multisample,
GLX_ATI_pixel_format_float, GLX_ATI_render_texture
GLX version: 1.2
GLX extensions:
GLX_ARB_multisample
OpenGL vendor string: ATI Technologies Inc.
OpenGL renderer string: RADEON X700 PRO
OpenGL version string: 2.0.6473 (8.37.6)
susan@susans-desktop:~$ glxgears
18754 frames in 5.0 seconds = 3750.750 FPS
22548 frames in 5.0 seconds = 4509.432 FPS
22547 frames in 5.0 seconds = 4509.303 FPS
22544 frames in 5.0 seconds = 4508.742 FPS
22550 frames in 5.0 seconds = 4509.934 FPS
22462 frames in 5.0 seconds = 4492.242 FPS
22553 frames in 5.0 seconds = 4510.500 FPS
Hard drives should auto configure.
I've never used Envy or tried to configure the mouse ( I use a trackball)
4) I keep hearing that using Ubuntu to modify files on NTFS drives is bad and shouldn't be done. So I'm obviously going to need to change these drives to something Ubuntu likes... but how do I do that? Should I copy the data over to my My book, format the drive and change the file system to ext3 then copy the data over?
Vista by default hibernates the box and doesn't shut it down - you need to select shut down instead of the power button on the start menu.2) My second "stuff" hdd with just loads of crap on it. I can't access it because Ubuntu is telling me it's in hibernation from Windows. Well it's not. I have restarted Vista but it hasn't done anything. How do I get access to this drive?
*nix operating systems have a hierarchical folder structure (a bit like mounting new drives to NTFS folders. As there are no C:\ or D:\, drives have to be mounted onto folders. Unlike NTFS though - these folders don't have to be empty...3) Mounting. What's it all about?
Up to you, really. I used ntfs-3g a while back and didn't have any issues - but I have heard of some. For me, a filesystem really needs to be 100% solid - so I don't use it. Options are really reiserfs or ext3. I use both and both have their merits.4) I keep hearing that using Ubuntu to modify files on NTFS drives is bad and shouldn't be done. So I'm obviously going to need to change these drives to something Ubuntu likes... but how do I do that? Should I copy the data over to my My book, format the drive and change the file system to ext3 then copy the data over?
Non hdd related. Do I use the SU command in Ubuntu? If so what's the password? Is there anything I should change since installing to make it more secure?
$ sudo passwd root
<enter new password for root - don't forget this!!>
$ su -
# apt-get remove sudo
$ sudo visudo
Correct. There are AV scanners for linux, but they really just scan for windows viruses so they don't get passed on. if there is one in an email, etc - it's not going to infect your boxI just want to make it as secure as possible. That's a point. Linux doesn't NEED anti virus right?
Not strictly true... there are third party drivers out there which give full read/write support to ext2/3. Most are **** - but a friend has one on his dual boot windows/gentoo box and I have seen it working (large drives as well, with no mucking about in the registry increasing pool sizes).outcast said:Windows Likes you to play its own way or its gonna take its ball back and not play anymore.
ie:
Linux can see & use Windows drives & files
Windows cant see Linux drives.
[/code]Code:$ sudo passwd root <enter new password for root - don't forget this!!> $ su - # apt-get remove sudo
Dunno what that is.and REMOVE the grace period.
