18,730 odd posts and you make a blatent troll thread, its a new tech release I dont even expect it to go smoothly and i'm in the market for a new card, are you looking for a new card at the moment? Because this seems to bother you and i'm not sure why if its not for blatent trolling
You can get the 570 for less than £300 but I think the 570 should have come in at £250 max. You know how initial pricing goes, it may settle down closer to £260.
Can't wait for the new cards as something as to give as no one will buy them at 300
Ok then, say you arent looking for a reaction from others just for the sake of it.
Why would I?
I have better things to do and that includes responding to lack lustre posts from you.
It's fair debate. I for one think the 570 is fairly underwhelming considering we have had the 480 since March that gives the same performance. £300 notes with less memory is too much IMO.
Ok then, say you arent looking for a reaction from others just for the sake of it. What is the problem? Are you desperate to get your hands on a 580/570?
Havent OCUK sold out?
New tech and so uninspiring...I have every faith in AMD's release both in terms of performance and pricing.
Have NV lost the plot?
@Relentless81
If you did a search and found out what hardware I have owned in the past you would see exactly that I have no loyality to anything when it comes to PC hardware. This is why your post is so laughable.
You took one look at my sig ( created as a joke in create me a sig thread) and have come to a conclusion that is neither accurate or relevant to this thread in anyway.
but you should be aware that not everyone is interested in your GPU ownership history and you should take that into consideration when you create a thread
