Thanks for the link.
You're welcome.
Personally I wouldn't even bother doing that test as I suspect that your time will be over 6hrs to drain meaning your test has failed since it's clay ground. As soon as the surrounding ground is saturated any water in a soakaway won't have anywhere to escape to so you'd effectively have an underground rock filled pool in your garden.
Do you know where your current house surface water drains to? Is it into the mains whether it's separate or combined or does it go off to something like a SUDS pond located somewhere around your development? It may be possible to connect into this providing there's still capacity or if other measurements could be taken to reduce the flow into these existing drainage solutions
Unfortunately this is the most likely scenario in a clay strata.
, it's the only way to sort it properly.
