Because the 4080 uses a 70 class die I could not bring myself to pay any more than £700 for it and live with the thought that I allowed Nvidia to skank me so hard.
But you say a 4070 class die? But define what a 4070 class die is? You are judging based on the 30XX series. To use the car analogy, you are saying dont buy the latest car because it is only 2.0L when the previous version was 6.8L but the issue is the 2.0L is a newer more revised engine that no longer needs to be 6.8L or even 3.6L because the revised 2.0 engine is just as good.
There is little point in harping back to past generations, the 4080 is a stonking card despite its price. the 4070 will not be a patch on the 4080.
I had a 3090 and I got a 4080 and it has been a huge upgrade especially in MSFS.
My 3D Mark Result 4080 @ 4k
AMD Ryzen 7 5800X3D, NVIDIA GeForce RTX 4080 x 1, 32768 MB, 64-bit Windows 11}
www.3dmark.com
My 3D Mark Result 3090 @ 4k
AMD Ryzen 7 5800X3D, NVIDIA GeForce RTX 3090 x 1, 32768 MB, 64-bit Windows 11}
www.3dmark.com
No overclocking. Its a fairly big jump and triple digits in MSFS, and all the new tech is amazing. I think people forget the 4090 is also probably the first GPU that can really push 8K. on my 3840X1600 Ultra wide ACER 38s that maxes out at 175hz what am I going to do with all that power. My feeling is the 4080 will last till the 50XX series and I hope NVIDIA get real with the prices then!
Stop listening to all these streamers that pusing out garbage lies. My Friend has a 4090 and honestly aside from the odd exception the FPS difference is what these streamers are saying in real terms. I get 138 FPS in MSFS, he gets 144-150FPS under the same conditions....big wow!! and I saved £520. It may drop to 40FPS at some large airports, his will drop to 55fps maybe even 50.
A few games can be 30-35FPS difference, but at that point it is usually above the 120hz range. He has the same monitor, but he also has a 4k 16:9 monitor as well as he wont play some games in Ultra Wide.
All I am saying is there is a **** ton of misinformation out there about how bad 4080 is, and when you have one in hand you will see that. I am not defending NVIDIA it is way over priced! but so is the 4090 IMHO.
