- 23 May 2006
currently at 18.7 with 14 exported. still pulling in 0.6kwh so should make 19 but 20 is off the table today.
Something took a big bite out of my solar production this morning, otherwise it would have been a record breaking day.
similar shape on my 1st half of the day too. 2nd half is slightly unusual as I have less panels on my west facing roof than east.Something took a big bite out of my solar production this morning, otherwise it would have been a record breaking day.
And here's the culprit, it moved from the east to the west, you can see above at 7:49 production dropped, and then at around 10:30 it shot up. The cloud edge peak doesn't look too high above, but when I zoom in it shows a peak of 7.6kW, and my own monitoring shows today's highest peak at 8kW.
I'm at the very southeast tip of Kent, right in the middle of that splodge of clouds.
Today's figures.
Generation: 41.28kWh
Export: 37kWh
It was indeed! Although I'm distracted with PV envy as my neighbour is getting 32 x 410w panels installed - they're West facing rather than South like mine, but boy they're gonna pump out some juice!!@katie279 new record today?
the graph is live data only...I just looked at the daily production of the radiation sponges and I can't work it out. very quick beer mat maths we generated 466kwh.
but according to the graph it was 153kwh.
I know my workings were rough but they won't be that far out.
AHH ok thanks .. so the daily, weekly and monthly tabs there are not accurate then. that is a shame.the graph is live data only...
i have added my output to the database on 1st page i went back to cover all april output and export. it is manual so won't be on the live chart unfortunately and relies on me doing it daily also won't have all the other info as I can't be bothered... I dug out an old nexus 10 tablet to install the home assistant server on but boy that seems a chore. may still give it a go but it's outside my wheelhouse really (I think I need to replace the os on my tablet, which needs me to install a load of stuff on my pc before then getting home assistant running )
my inverter gives me a key and a link to the API. such a shame I can't just plug that into the spreadsheet.
