I haven't been home in 3 days so I have no idea what the situation is!![]()
The situation is moist
The best kind of situationThe situation is moist
Thanks for the confirmation.I don't know. But they've arrived here as well, rain included.
Hopefully it was the ones on the panels.
Basically yes, but if you suffer with lime scale then not a good idea to use tap water apparently.
7.8kwh total max from batteries (2.6x3) but it'll only top up to 5kw total, so if I'm generating 4kw it'll only supplement with 1kw if that makes sense.how much do you dump from the batteries at 4pm??
You exported more than you generated or typo?Been a bit of a grotty day down here, it really dropped of after 1pm.
Still generated 26.72kWh and exported around 27kWh.
It's a typo, should be 22, thanks. Although I could in theory export more than generated as I always charge the battery overnight.You exported more than you generated or typo?
Wow, how much battery storage have you got?It's a typo, should be 22, thanks. Although I could in theory export more than generated as I always charge the battery overnight.
Hes got a lot and hes building more…Wow, how much battery storage have you got?
