- 7 Sep 2020
- Gods Country
Just got into double figures today with 11.1kwhs……
Tbh we need the rain…..so for one night im good with it. After tmrw we forecast for 8 days straight of 25+ degrees of sunshine29kWh today, keep the thunder in the valleys welshman!![]()
you dont need to cut power...it runs off usbNice Welsh, btw you hooking that iotawatt up yourself? Can it be done without cutting power safely?
I mean when putting the clamps on, fiddling with the wires to get them round. Hope it all works ok.you dont need to cut power...it runs off usb
clamps are already fitted to other sensors. You dont need any body fitting them for you...its easy peasyI mean when putting the clamps on, fiddling with the wires to get them round. Hope it all works ok.
Mine were pretty clean after last nights storm, we got more rain forecast, but nothing has arrived as yet.yay just after I posted above the rain came
Panels look better although wont be able to tell for sure until they dry off again
Probably a 5 minute shower so could be enough to have got all the dust and stuff off
Maybe you should have had some of our rain, to clear those clouds. Just a little over 16kwhs hereTerrible generation ~10kWh, last time it was this poor was twenty days ago.
