Solar panel production figures
22.7kWh generated and 7.2kWh exported.
Used 17.6kWh and imported just 0.2kWh.
We've had the air con on full blast so the battery is already down to 32%. Should make it to morning so hopefully it starts off sunny!
Up to 700kwh for the month.
Just put an order in for another 5 panels to add to my system, take me up to 8KW of solar. Two EVs are sucking it up now.
Where you putting the new panels?.
Start on the house roof which is untouched at the moment. Probably space for another 20 panels if/when I decide but that will require another inverter as I ll be maxing my current one out at 8kw of pv.
Awful day, barely any sun. Thunder and lightening around 4pm. Panels happy to not need a clean for a while now..
Another sunny day until mid-afternoon. Generated 29.9kWh and exported 3.4kWh. Just passed the monthly target of 562kWh aswell.
We used over 24kWh ourselves with just 0.3kWh from the grid so a good saving.
just teasing you mate..... reports of hosepipe bans in kent due to water shortages lol
Ah, you see, we are Southern Water, it's South Eastern Water that has the hose pipe ban, so only affects some parts of Kent, it's always guaranteed to confuse the locals, so outsiders have no chance.
