Solar panel production figures
Sending some share of the cloud/wet to Ronski should land midday tomorrow according to the potentially accurate Met office.
No rain forecast until tomorrow night, some clouds from about 15:00 though, Thursdays looking bad with thunderstorms forecast.
Still averaging over 45 kWh a day.
26.8kWh generated and 11.6kWh exported.
On 597kWh for the month. I'm guessing we'll finish between 650 and 700kWh so not too bad considering how poor the first 10 days of the month were.
Looks like I'll easily beat May's production.
May was 834, currently on 828 - I doubt I'll ever break 1MWh in a month but I'm happy with getting close to 900.
June has been good for me.
Forecast was 526, I am already at 670. 750 is probably not going to happen now since the weather looks iffy.
726 would be nice, 200kwh over forecast!
I am going to finish H1 about 2500kwh.
I am still frankly a little amazed at how much energy I can harvest. At around 20% efficiency.
Imagine if panels were over 50% efficient.
Agree.
I wonder how much simple heat can be harvest by the panels that have liquid cooling
When you read that panels can be 30 degrees warmer than ambient that puts them well into the 50s regularly.
50 degree water would be great with just a small boost required to get to 60.
Been "ok" here, won't be setting any records.
I will need to dump my batteries later anyway, having a new BMS fitted today and to see if it fixes my charging issue I will need to empty then fully charge the batteries.
Good thing is the diverter detects that anyway and will send it to the hot water tank, well mainly, it can only divert 3kw, batteries will dump at 5.5kw
Forecast has turned to a pile of poo for the next fortnight. Have scrapped over 900 for the month today, absolutely smashing the estimate for this month of 703.
Good luck with the new BMS mate
The worst day of the month with just 7.8kWh generated and nothing exported. The battery didn't even charge past 72%.
9.6kWh here, took the edge off what was promising to be a strong month unfortunately. Will hope July evades some of this wet rubbish.
Next few days are looking pretty average, but I’m on 964 for the month so if I can average just 12kwh per day for the next 3 days then I will breach 1MWh for the month which is a pretty cool figure!
