I'm using Givenergy, although I've got the kit ready for HA, I've still not set it up.I have a plan to increase mine 50% by adding an overhang on each side of the workshop which means I can add 4 more panels each side and conveniently also get a load of extra storage space outside the main shop. But even then it's a mere 9.45. Given the E/W split, the best my 5kw inverter hit yesterday was 4.2kw so while I'll clip on the very best days at the peak, it would do good the rest of the year.
I'm assuming anyone using the Giv stuff is also using Predbat at this point?
I will be doing shortly if I don't get side tracked with other projects but I'm fortunate that my battery capacity is large enough to cope with good generation in addition to export/home load.
The 5kW Gen2/3 can cope with 8.3kW total (3.3kW to battery and 5kW to the house/grid at the same time) PV size dependent.
They can also cope with 7.5kW PV per string again, voltage limit dependant.
