Solar panel production figures
Nice one, all working and producing nicely I see.
yup....was easy peasy once the efergy hub was set-up that kate sent me......added a token straight from efergy into pvoutput and all is golden.
Ive also got it polling every 15mins, so less data is being passed across and it shows the increases in production better for me.
Seems I got my weather forecast wrong again and charged battery to 60% overnight. 22kWh so far and almost 10 of that exported, if it carries on like this it could be a record day. Sun keeps going behind clouds, but regularly generating over 6kW.
16.2 against a solcast prediction of 25 last night. Got some 6kW peaks in a couple of times, once again not home so no idea what it was like.
Finished the day at 28.37kWh, turned charging off overnight, as the weather forecast looks similar to today.
On target for 515kWh for the month, going by daily averages.
We got a rather nice 23.3kwh today from our 4.7 system which pretty much covered us from 6:30 this morning and had me frantically finding washing to do:p (3 loads, and about 90 minutes of tumble).
What wasn't so good was the loss of nearly 5kwh to the grid :(
I need to sort out the export payments but the British Gas form seems to be in the wrong format for the MPAN/boxes are far too small (the box for an 8 digit number is barely larger than the one for 4, and a 3 digit box is only big enough for on digit)
[edit]
I think i've worked out how to do the form, I copied the mpan from my bill, and printed it out at the right size using a dymo label :p the numbers have to be around 4-5mm high
Very up and down weather today, sunny one minute, overcast the next.
Around 7 kWh so far today which is tracking a little under my expectation based on original Solcast data, it doesn't think the forecast will improve so I may just get 9-10 today in the end.
23.22kWh, tomorrows weather is forecast as 80% chance of rain all day, so I'm going to fully charge the battery tonight.
