18 X 410w so about 7.4kw
And 19.5kwh of batteries.
Definitely eyeing up other spots for more panels though .....
the problem with the ev is it depends on your usage of the car as well, if your commuting daily its useless as you'll want it charging overnight and it won't be there to charge during the day...
Yeah - have a Nissan Leaf and other half has a Tesla Model Y on order, so am hoping this will be a good 'outlet' for all that extra electricity, but at the moment the car is full, our batteries are at 100%, solar is producing 6.6kw and we're exporting 3.6kw (which is burning it!).If you've got an EV you should be able to utilise pretty much all of that spare from the solar generation. Thats the bit I don't have currently, but if I did have an EV I suspect i'd barely export anything.
Yeah, we were energy free at 8am this morning despite a thick Scottish fog! Sky has cleared and producing 5-6x what we need now!Very nice, sort of tracks with my peak generation yesterday around 80% of the panel capacities, but today is not a clear day here, it's bumbling along at anywhere from 800 - 3000W today, depending on cloud cover and sunlight appearing.
My system is 4.8kw so would not expect it to go above it, and is split SE/SW so I'd expect peak generation in the early afternoon on sunny days
So what's the craic with all these charge points in spaces - can people use them after they get to work/whatever, I assume its not free but at some work places isnt this going to be the point that charging it elsewhere means not just at home overnight?
Good shout Troop - I've pulled my finger out and have signed up today!@Ron-ski . Yes GO is locked for 1 year from the date you sign up to it.
If you're going to go for GO, I'd be quick to get on the 7.5/40p rate..... rate will probably go up over the next month.
We need a rich and varied charging network at destinations for those that can't charge at home (flats, street parking etc) and those traveling longer distances. Service stations work to some degree but due to the longer charge times its not ideal. Given the crazy rise in energy costs its getting a bit silly to charge on the go if you can charge at home on a lower rate...
We've not got an EV either, if they ask what's the next best option? Hope to have a battery up and running in the next couple of months.
Thanks, what's the costs on the variable tariff - I would look it up but so many tariffs.
Thanks, thought they weren't taking customers on at the capped rates, but I suppose with the cap increasing very soon it doesn't make much difference.
I'll dig out my info from the last switch and call them tomorrow.
Did you end up paying Bulb anything, and if so did they refund it quickly?
