I've considered this as we have a battle with moss on our tiled roof. When the scaffold was up for the panels I scraped and brushed it all off, and if I spot new moss growing I am going to spray a product like "Wet and Forget" above so it runs down behind the panels which does kill moss very effectively but relies on dead moss washing back down the roof afterwards which doesn't completely work so failing that the panels are high enough above the tiles that I will be able to get a scraper in underneath them.Can you clean under panels? Pur roof has a serious moss problem which I'm about to get sorted but I'm concerned it will come back and have no access under the solar panels
I've thoug
Good sunny day here, so doing a cheap pyrolytic clean on the ovens.
I've been looking at these guys and their premade packages
Solar PV Systems | Solar Panels & Battery Storage | Deege Solar
Affordable Solar PV Panel Systems, compatible with Social Energy & Agile Octopus. Including Battery Storage and Nationwide Installation.www.deegesolar.co.uk
Do they look like decent selections?
Great, that's good to know, but I could use them as a guide for what kit to pick at least?I have basically the same package as they are charging £12.5k for, (3 less panels) we had it installed 3 weeks ago for £9.5k and I thought that was a little over priced when I checked out the component costs.
At 12.5k it seems a rip off if im honest.
Start with your need. What's your daily consumption and split through the day. Do you have/might you have an EV in future? What do you think your peak demand is?Great, that's good to know, but I could use them as a guide for what kit to pick at least?
