One more thing, just to be clear in my head, the dark green CT clamp shuts the battery down, if it flows to the left. It can only flow to the house?This is my best paint mock up of what you'd want ideally:
The light green CT clamp enables you to change from solar if you want.
The dark green CT is for your battery so it doesn't cover the CT charger but covers your solar and house so it can charge/discharge properly but not discharge into the car.
The yellow CT is 'if fitted/needed' in the case you have an export limit and your solar inverter needs to curtail its output.
EDIT: of course the battery, solar and house can be combined into 1/2/3 consumer units, that doesn't matter as long as there is physical separation to the EV charger to get that CT clamp on for the battery.
Therefore I cannot export/sell my battery to the grid?
