stop showing offA G2 is still slow![]()
Showing off is for next week, when I up the charging power from 4kW to 8kWstop showing off![]()
Gen3 already available only difference to Gen2 though is 15A solar input (Gen2 13A, Gen1 11A).Maybe G3 by then!![]()
sounds about right on the pylon batteries. I have them and they will happily run a 3kwh oven kettle or air fryer ... but only because the demand is not long term , it's in spikes which the battery can manage.For those that know a lot more about this than me and hopefully some here have what I am inquiring about.
Pylontech US5000 I was recommended by solar+battery installer but everything I can find say they have a normal output of 2400w on draw but installer said that after speaking with manufacturer they are 4800 but that is peak short duration draw not sustained and im getting really frustrated with the whole battery situation delaying my install due to the whole batteries not VAT free unless you get them whilst installing panels blah blah blah.
I got a quote for 14x395 Panels, 3xUS5000 and 5kw inverter but I want batteries that will go up to 4-5kw normal draw.
I got ~16,000 for an install and wanted to get as much battery storage I could after getting minimum 5kw worth of panels on roof.
RE tumble drier.. next time you replace it get a heat pump. more expensive and take longer for sure but it sips power . our worst is a full towel load which takes maybe 4.5 hrs but it less than half the power of our old condenser and its peak use is really low so the battery can cope with it should it over run our cheap energy period. also means it can run directly off solar (no comment on why we use tumble drier on a sunny day)
Yup seconded. And the drying capacity will be less than the washing capacity so you have to unload part anyway or do a small wash. Stay with seperate applicances.Washer dryers are usually not as good at both washing and drying.
