Tigo are optimisers, they work by bucking the voltage on underperfoming panels (reduce the voltage output of underperfoming panels to increse the current across the string back to un-shaded levels) and they offer very similar monitoring to SE. It’s lower cost because you don’t have to buy one manufacturer’s much more expensive inverter and battery. The actual optimisers themselves are comparable in cost (£40 vs £60) to solar edge’s. See my previous post for two reports (albeit selected by Tigo themselves) outperforming SE in various scenarios including shading.Tigo are not what I wanted, they are not anything like SE optimisers hence the low cost,
Also here for a similar question on SE vs Tigo vs Enphase and some useful links from there https://forum.cleanenergyreviews.info/t/tigo-vs-solaredge-for-heavy-shading/1546/6
"SolarEdge usually requires a minimum of 8 panels to operate efficiently. This is because the SolarEdge inverter requires a combined 360 volts from all the optimisers, and standard optimisers only boost to a maximum of 60 volts. If you have less than six panels un-bypassed, the inverter will go offline. In short, the SolarEdge system does not work well in heavy shade."
I’m glad you like your SE system it is great tech, but it is not correct to that it is the only or necesarily the best option when it comes to dealing with shading.
