Sorry about the delay.That seems to be a really good price to me.
Where in the country are you and who is the installer?
Based in Derby and the installer is MyEnergy Solutions, who have been great so far.
Finally should be getting my solar+battery installed this week after the dno taking over 3 months to approve my g99. We are currently on Octpus standard variable - which tariff should I ask to move onto once my solar is up and running?
I'm guessing no EV? I'm just about to ( end of the month approx) come off Octopus Flux - as long as the rates remain relatively favourable, this might be suitable for you from April to October.10.5kwh solar + 10kwh battery all solaredge.
daily usage is about 22kwh
I think to keep things simple I will just try the standard 15p export tariff. Do I just need to call Octopus once our array is up and running?
Yep no EV. Trouble with this Flex type products is educating the family to stop using power heavy things in peak time.10.5kwh solar + 10kwh battery all solaredge.
"huge battery" eh?bet the wife is now satisfied....
So is the standard 15p export tariff my best option?
One of the reasons I went with such a big system, Charging, and peak discharging is all automated, and we can carry on as normal without thinking about what we are using, if it's pitch black outside we can draw 8kW.as long as the batteries still have charge and not draw any from the grid, actually we the inverter can peak far higher than 8.You can plan around it but it does take behavioural change. You also need to ensure the battery is charged before peak usage and can actually provide the necessary power to ensure you're not drawing from the grid
Ok, for the coming winter do I just need to call Octopus and tell them I have solar so they can enable export on my account? I'm currently on the octopus standard.For the approx 6 months for winter (Oct-Mar) you really want to minimise incoming costs, your not going to export much with your system vs consumption
The summer months, April - Sept approx you may be better off maximising export
You need to know if you can easily set a sensible position in regards flux export, some systems are easier and/or more customisable than others, including if you want to dip into HA
You really need a simple model so you can work out costs for the winter period and summer periods by month.
A lot is simple luck in regards generation, and such so there is no perfect position to take
Everyone is different so its pretty much impossible to say the best tariff is this, best export is that
You can do it all online, you'll need your MCS number and DNO confirmation both of which the installer should supply you, then you can apply.Ok, for the coming winter do I just need to call Octopus and tell them I have solar so they can enable export on my account? I'm currently on the octopus standard.
