The current Fox 5kw inverter allows 6600w of panels with 3300w maximum on each string, so its no good for either roof really as it'll clip massively on the most productive SE-facing array especially. It would be clipping pretty much from 8am - 3pm at least 6 months of the year.
I think ill explain what I'm after when the surveyor comes here. It was a fight the first time around getting anyone to quote with a 5kW inverter. Someone around the corner got a 6.4kW array and they were still quoting with the standard 3.6kW inverter even then.
I want the bigger inverter for the house load and don't fancy losing anything to clipping on a system what will already be yielding about 60% of a south facing system. I'm also not confident it'll work as smoothly as hoped with two inverters, as evidenced by issues people have had on the Fox support forums.
