If I'm not doing anything at all the power usage is 180w baseline, that is all of the background appliances in the house just ticking along.
There are 4 extractor fans that run in the bathrooms and kitchen all the time, albeit slow until you turn the lights on then they ramp up, but it's just designed that way to extract moisture from the air, probably using a few W between those. Beyond that I have router and a few switches, two tv's on standby one with an AVR/amp, some other various electrical devices like switches (x3) and hubs (hue, hive) along with kitchen appliances like my American Fridge/Freezer and my Quooker boiling tap thing.
After that 180W (4.3 kwh per day) it boils down to usage on top. TV is apparently around 170W in normal mode (it says energy rating G 171 kWh/1000h), 300W in HDR mode, but I mostly have it in normal mode, but as mentioned I have an AVR with a 5.1 speaker system, and that isn't no power. If I switch the TV on and the amp I think it would use a good 300W or so maybe as long as it's on. Standby on the TV is low it says 0.5W.
PC just ticking along will probably use another 150-200W without doing much with it.
I have a Synology NAS with multiple drives in which also eat some power but that isn't included in the baseline stats.
I'm pretty good at turning kit off when not in use, but combination of higher usage when on and a higher baseline means at the moment I am often using 15~ kwh per day at the moment. I think in more normal times that would be like 10 kwh per day but I'm quite a heavy electric user apparently.
