Good point - I will check its a fully installed price with the g99the quote is good, assuming it includes scaffolding, bird protection and the g99 application
never used solar express so cannot comment on the company
No, it’s just the additional margin solar installers were charging when demand outstripped supply, the same applied all the way up the supply chain.And another email from the hive quote offering 1k off the quote
Has there been any big changes this mo th?
It’s such a silly nonsense when people do these sort of things.Likely to be work drying up.
People tend to want solar in the spring and early summer as they think it will gain them more
Now supply has increased and demand has dropped, prices are coming down quickly. Realistically I don’t know how much lower the equipment costs are going to get, it’s very competitive out there at the moment.
Any sensible person would realise you don’t get any less benefit out of the system installing it in October than you do in June, it just lacks the instant gratification.
Ive amended application to fit 4.6kw inverter instead……so no G100 required then@Welshman @gpuerrilla This is the correct thread for the questions you're asking in the Solar panel production thread
G100 export limitation is set in the inverter, or sometimes a separate export limit box (no idea how that works). The inverter needs to be certified for G100. You can check if an inverter is certified at https://connect-direct.energynetworks.org/device-databases/search-gen
I've no experience of G100, as I was lucky, but they may need to witness it being setup and commissioned.
I was just in the process of replying to your DM, suggesting a 4.6kW inverter.Ive amended application to fit 4.6kw inverter instead……so no G100 required then
It came via a pallet delivery company in a create on the back of a 7.5T lorry with tail lift - pretty standard for a large delivery like that. It was unloaded with a standard pallet jack and wheeled into the garage easy enough.I assume they use a specialist courier - my regular DPD guy was not amused at me for having 33Kg batteries delivered never mind 140Kg all in one.
