Solar panels and battery - any real world reccomendations?
@LordVader Imo that is about £2k over par.
I have east, south and west roof arrays and the east and west do a good job, you get a nice full day of production.
Also get a bigger inverter if you can. You can always throttle them back if you’re not allowed to export more than 3.6kw and they cost almost the same.
What is the advantage of having a bigger inverter if you can't export more than 3.6kw?
Still learning all this PV/battery stuff
Just a shame no where has any panels in stock :p
Update on my DIY system.
New 7.2Kw battery added.
Batteries cover most use from 4.30am - 00.30am (20 hours)
rest of the time it's cheap rate @5p per unit
For the next battery.
My electricity use/cost for the last 31 days
Hot water at the cheap rate is 2kw a day of the total use.
@Troop Nice, what's charging the battery? I'm considering doing my own 16S battery.
4 panels in the garden, if you look at my post history I posted a pic of it in one of the threads on here not long ago.
Plus a charger all wired in to use in the winter months to run at the cheap rate.
Those tariff prices are awesome.
Octopus GO tariff, runs out end of September I will be gutted.
@Ron-ski
Found the pic.
What @Journey said plus hopefully your DNO won’t limit you.
If you are getting a hybrid inverter then the battery charge is at least in addition to the 3.6kw which is the max it will feed to AC so house/external battery charger/grid (and will be on a 16a breaker in the consumer unit rather than a 32a for a 5k or 6k inverter).
Found the pic.
It is truly ridiculous to think that a lot of people assume you need a massive solar array to make a big difference to your bill. Small amount of panels, well positioned, with a battery will cover most of the needs of the average household.
I am producing so much excess its silly, but I am using the SEG returns to offset the upcoming winter prices, I've even been charging the car with all of the extra generation.
^ This - Demand is massive right now, so prices are going up (and kit is hard to buy)
I don’t dispute that, but I had quotes of £10k - £14k for the same system, there is a lot of variance between installers.
Another quote come back, this time from a big national, GlowGreensolar if anyone has any experience with them?
Q Cells 395W Mono Q Peak Duo ML G9 Black Frame MC4 solar panel 20
Solis Energy Storage 6kW Hybrid inverter 1
Emlite Hybrid Only Bi-directional Meter ECA2 1
Label sheet 1
DC cable warning sticker sheet 1
Solis Wif Stick DLS-W 1
AC isolator - KN 32A 3-pole 2
PureDrive PureStorage 2 10kw
DC isolator - KG20-4 2
Pair of MC4 connectors 4
50m reel of 4mm2 solar cable 1
This comes in at £13,577.48
Label sheet 1
Have a read of their trustpilot before proceeding. They were the cheapest that quoted me but their trustpilot put me off..
Found the pic.
I remember it now, nice setup, and great tariff.
I excluded GlowGreen as I couldn’t get comfortable with the PureDrive battery. PureDrive are a startup and there were no online reviews. Maybe someone on here can comment. As the largest single expense and the part most likely to degrade and fail I wanted a track record. They have copied the Tesla styling (nothing wrong with that) and appear to do an AC and a more conventional DC coupled option. Good to support UK business of course.
To those with solar - are there winter days where you produce 0kwh? What would a typical winter day look like in terms of kWh production?
That looks pretty good, do you have any details on the batteries and how you sort them out? Is it one of those LiFePO4 battery setups?
