No idea, company car was originally due to be delivered in May and current date is October...Might offer to charge my neighbours car at this rate.
Both lol and oh dear. No other options on the table then?
No anti-bird stuff installed?
@BUDFORCE You'd best get some anti bird stuff installed before the scaffold comes down or you'll regret it.
@BUDFORCE get a nerf gun. Pigeons don't know which way to fly, plus it makes you smile like a little kid.
No Pigeons were harmed in the making.
Nah, she has one already, so will just have to wait, could come forward as she knows a few colleagues who had it pushed back then miraculously moved forward a month later.Both lol and oh dear. No other options on the table then?
That's a pretty decent price IMO. Try and get another couple to compare against but it doesn't scream over priced to me overall, could argue that some of the bits are slightly expensive but other bits are very reasonable indeed so the bottom line number is fair.Got the first quote in the other day for an install how does this look?
- Trina Solar 390w Solar Panel £170.00 x12 £2,040.00
- LUX Power Hybrid Inverter + 7kw Battery £6,000.00
- Emlite Generation Meter £25.00
- Electrical Equipment + Cabling + MC4 Connectors £575.00
- Roof Mounting Kit £525.00
- Scaffold £750.00
- Goods Total: £9,915.00
- Description of Services Qty. Unit Price Total Price
- Survey £0.00
- Installation & Commissioning of Solar PV + Battery £1,000.00
- Register Installation with HiES & MCS £0.00
- Services Total: £1,000.00
- Goods & Services Sub Total: £10,915.00
- Delivery costs: £0.00
That'd literally half my bills then, I suppose you've got the how many etc and costs of the itinerary/supply. plus it's probably seasonal for the amount you can save per month based on the weather@goldy6660 That really depends on so many variables, how much you use, what size array, whether you have a battery, and if so how big.
I have a 4kw array, no battery and using about £100 of electric a month at the moment.
Bill before I got my solar installed (PV only - no battery - 3.68 kWp inverter) £271, first full month with solar £132, that's gas and electric, my usage would have went down a little from May to June without solar but not that much - I'm on the price cap at the moment.What are people's electric bills like if you get solar?
Thanks that's fantastic, I'll take a look at suppliers in Cheshire then. At that rate it'd pay for itself in less than 10 years and then you're in the plus!Bill before I got my solar installed (PV only - no battery - 3.68 kWp inverter) £271, first full month with solar £132, that's gas and electric, my usage would have went down a little from May to June without solar but not that much - I'm on the price cap at the moment.
I'm using an eddi to heat my hot water, I've seen good savings with that.
Next steps will be to get a battery of some sort but I'm waiting on that technology to move on a little and see what happens with Vehicle to Home as if I can use an electric car as a battery then I don't necessarily need to get a battery in the garage. Also move onto a tariff that allows some sort of cheap off peak period where i can charge the battery.
Currently I‘m just using solar energy - it powers my house, charges my home battery and heats water - so no gas use either.What are people's electric bills like if you get solar?
if you aren't getting a battery a standard inverter will be fine, you can always add an AC coupled battery system later. You'd need a hybrid I think if you are adding a DC battery (I think).Sorry if this is a daft question but what make inverter/battery should I be looking for? I heard lots of mention of GivEnergy and SolarEdge are they the best? Also are most 400watt panels the same or should I go for a specific make.
The type, should I go for Hybrid or standard? I will be calling companies for quotes in the next few days. Thanks.
Ok so provided they notify building control your good?
April electricity bill all on grid £100.11What are people's electric bills like if you get solar?
Buying a Tigo Tap and CCA (£250) will reveal which of your panels/optimisers is knackered but you will need the serial # of each Tigo…Urgh, thought my panels were underperforming as they were dirty, but turns out I have in issue.
Either a panel has gone or a tigo box isn't operating.
What's the chances of the warranty working, as I've had pigeons under there....
