Those panels may be smaller than larger watt ones, so getting bigger panels may mean you get less overall kW.
Did you have the uprated inverter installed in the end?I've made a decision to swap out my GivEnergy kit (inverter/batteries) for Victron gear, as I want more from it now. If all goes to plan I'll be using the V2L from the new car in the generator 240AC input on the Victron inverter to power the house, so will have a 55/70kWh battery on tap most evening/nights. It''ll be great for when the solar isn't supplying what we need, and we can charge at the cheap rates over night. Would love more panels but I'd have to build a new roof for that! It's going to be supporting a house running on full electric, no gas/oil etc. so I feel this is the right move to make.
Nope, it was due last month and was delayed which kind of made my decision easier. Plus I have a buyer for my kit already, and I am making more back than I spent, so I will only be outlaying for the extra kWh for the new batteries, the rest will be covered by the Giv sale.Did you have the uprated inverter installed in the end?
Last two days after the heat of Tuesday night and getting my battery down to 4% reserve i've not been able to get it up above 70% charge due to the cloud cover. Just about got me through the night, but have had to turn the AC off for the first time in 3 weeks today to ensure i've not pulled anything from the grid well I was out so it didn't matter, but suspect will be back to normal operations tomorrow. But another learning for the future to minimise any unneccesary pull.
Just had my first quote in:
Solar Panels
Jinko Solar Co., Ltd.
7.875 kW Total Solar Power
21 x 375 Watt Panels (JKM375M-6RL3-B)
6,480 kWh per year
Hybrid Inverter
GivEnergy
5 kW of Total Inverter Power
1 x GIV-HY5.0
Warranty coverage of up to 5 years extendable to 10 years
Giv-Bat9.5
1 x Giv-Bat9.5
9.5kWh of Storage
10 Year Performance Warranty
£11,606
Not heard of those Jinko panels before and 375W seems low?
If your panels burn your house down and you haven't informed home insurance, there is a risk it could invalidate the home insurance afaik.
That is why I would tell them about it, not worth the risk of not telling them imo.
I may well have done, will need to check policy etc.
I don't remember being asked about it for a new home insurance application, so it seems a bit weird, if I apply for a new provider I'm not even sure if it will come up as a question.
I completed one recently and it wasnt something I recall being asked.
Any update on the inverter @BUDFORCE ?
12 * Trina 385w Panels (4.62kW)
Solis 3.68Kw Hybrid Inverter
But also remember some do this to ensure maximum generation when it's too hot or towards the spring and autumnSo your panels will generate more than your inverter can handle?
Seems a bit inefficient, I bet it's 3.6 so they don't have to do the DNO paperwork. I'd avoid number 2 personally, these are different companies?
