Sony XF90
This is what CEC is for. If you wake the telly up by pressing a button on the Apple TV remote it should turn the telly on and switch to that input. My shield does this as does Sky Q and my PS4.
yes true, that works really well. I had been using the Sony remote but actually doing this is probably the way forward.
hey, just registered to ask you guys a question: could you get your xf90's working with a usb dac? i have tried multiple ones, tried to enable audio output in the developer settings, nothing worked. any workaround would be appreciated. thanks!
Anyone think the LG OLED55A16LA would be much of an improvement over this. Can be had for £700 from AO at the moment.
Heads up for anyone still using this set , just noticed apple tv has finally arrived searched for it loads of times before so must be a recentish addition.
Nice one. I check periodically just in case and last looked around a month ago. We use this TV in our bedroom and should be able to ditch (repurpose) the firestick now.
