Raist said:Proof is in the ceiling?
lightbulb a contains gas and b contains no spark just white hot glowing metal.
spark needs a gas to travell across but not necesarily oxygen. ie it would work in co2?
laiman said:lightbulb a contains gas and b contains no spark just white hot glowing metal.
Lightbulb B has glowing metal due to sparks jumping around it continuously (electrical arc).laiman said:lightbulb a contains gas and b contains no spark just white hot glowing metal.
NicktheNorse said:are bullet cartridges air tight?
SoSolid said:There is no air in space, how do you think a rocket engine works?![]()
Nah.William said:I thought they were liquid hydrogen and oxygen mixes?
Surely the bulb would explode due to the extreme pressure gradient across the glass?divosuk said:Even a 2mm thick sealed glass bulb has leakage in a vacuum. Any vessel at total vacuum will evetually leak to even out the pressures.
Moredhel said:A torr is a unit of pressure. And we're saying a gun could be fired in vacuum at first, but not after a while.
divosuk said:Torr is a measure of pressure....same as Pascals, Bar and PSI.
info
Space is about 10-15 to 10-16 Torr. Machines I work at operate at 10-10 Torr and take 24 hours to pump down using turbomolecular pumps -almost total vacuums - and a lot less atoms than most things on earth.....Atmosphere (or air at sea level) is approx. 760 Torr.
And in answer to the question - a gun would fire (if it were in a vacuum for say less than an hour)....any longer, and the combustible gases in the cartridge would leak out and render it useless.
Tried&Tested said:
"...you can't have one without the..other!"
[IMG]http://www.sonypictures.com/groups/us/documents/image/pr1026900.jpg
