William said:A-Level chemistry says you need no oxygen.
Spark can be a glowing hot particle like metal flying off a angle grinder.
Or an electrostatic discharge like a sparkplug which needs a gas to travel across.
no you need oxygen in that case, The metal is glowing because its oxidizing (see that word) in the air.
I'm sure there some exceptions but most of the time yes you need oxygen for a spark a spark is basicly fire after all.
spark (FIRE/ELECTRICITY) Show phonetics
noun [C]
1 a very small bit of fire which flies out from something that is burning or which is made by rubbing two hard things together, or a flash of light made by electricity:
Sparks were flying out of the bonfire and blowing everywhere.
You can start a fire by rubbing two dry pieces of wood together until you produce a spark.
2 spark of anger/inspiration/life, etc. a very small amount of a particular emotion or quality in a person
