Caporegime
- 21 Jun 2006
Well I've just swapped out some CCA for OFC on some Kef R500's and the difference is negligible.
Not entirely sure how something like van damme can be justified.
their is pretty conclusive evidence that as long as it's 2.5mm squared OFC then that gives you the best experience possible for normal conditions even longer runs. short runs can even use less like 2mm or even 1.5mm but there is usuallu zero point in going higher than 2.5mm unless it's a ridiculously long run.
so yes van damme cable is expensive as you can get 2.5mm cable from other suppliers for much cheaper. currently the german supplier on amazon is the one most are using.
as for CCA being the same it depends on the run (yours was very short so it's possible it made zero real difference in upgrading) and how good your amp, speakers, content, source and hearing is. it's the same when you give someone a set of £50 headphones and a set of £500 headphones and they cannot tell the difference. it depends on everything else in the chain too.
