how long is the lead?
Huge, 7.5m!
Huge, 7.5m!
Hmm... I haven't seen the IR reflection at night or condensation problems. They're mounted and fairly sheltered below the pvc plastic of the house.
Each camera only requires a single cat6 cable. No power cable is needed as this cat6 cable will carry the power and data. Have all camera cables located back to a central location we’re you will have your NVR/POE Switch.
IVMS-4500 is mostly used by those that are within the LAN network and Hik-Connect is really the remote viewing app of choice when outside of the local network. Notifications are good if trial and tested to get the best results. They aren’t perfect but none are.
You are better going for an 8 cam NVR such as the DS-7608NI-K2/8P. If you decide to add another camera, you have the capacity to add it.
Hikvision does white/Grey/Black bullets but depends on model. To be honest, stick to turrets, not bullets.
Forget the 2355 or 2385 turrets. Crap at night. The 2335 3MP and 2345 4MP turrets are miles better in night performance over the 2355 and 2385. The 2335 in particular and the 2345 are darkfighter/low level light cams.
I know someone that will be testing a new cam shortly so I hope to get some comments.
That's the only thing I really despise about the bullet cameras. Is the amount of times I've to clean cobwebs from them.
Excellent, thanks Scream.
One more question: I assume the NVR's support DDNS for remote viewing and notifications etc?
yes, and they support Hik-Connect app where you can use their account system to log in without having to pay for a DDNS if you don't want.
I'll be avoiding the Hik-Connect app and using my own DDNS, for better security.
Hahaha! I have a Swann system currently with bullets. I have to clean them every week or so![]()
