Just about to but another Hikvision camera to add to my old bullet (may replace that too later).
I have read the Colorvu are the latest best thing but confused which to buy.
The link earlier in this thread is for a 4MP and is about £120. (Also on auction site for similar)
But I also see on the auction site some 5MP models for half the cost. Are these newer or any good?
Which should I get?
Thanks
Thanks but too technical for me. Need simple guidance.
I'd get a couple of 2.8mm and put them roughly as below. You'll be able to position the lens to maximise the capture range.
Thats great thanks, Ill get 2 and put in locations you suggested. Will I need the wall bracket or deep base for both?
Anybody here use Blue Iris as the NVR? I had 6 Duhua 2Mp starlights cams installed last year with a PC running BI. Has been running fine but am wondering if anybody else is using BI and their overall thoughts on it?
I know there is a lot of people with ring cameras on here, you might be interested in this:
Amazon's Ring logs every doorbell press and app action https://www.bbc.co.uk/news/technology-51709247
Food for thought, I expect nest is exactly the same.
