Pretty much par for the course with
Amazon and google
Your data's the thing that's worth money to them
Amazon and google
Hi guys, ok long story short I'm going to get a wireless camera for our front bedroom looking outwards onto my car, need to be on a stand and angle adjustable
Recommendations?
Cameras aimed out a window
Have seen the new colourvu footageAny IR will bloom back at you though normal glass
I have the older YI outdoor 1080p IR but the new Kami 1080p model has colour night vision as well as IR so it will work though glass if you disable the IR as I have tested this recently with a Reolink Argus 2 (it had other performance issues and limitation issues so sent it back).
https://cctvdirectonline.co.uk/4mp-...UZ_uSqfuSrZPRdx-xirSjoJJi6sWCQvIaAkWBEALw_wcB
Experts, I've been waiting on a colourvu in grey, before I pre order this camera what do I need to check to see if this will work with my Synology NAS?
DS916+ here and the colorvu work fine with it.
Hi all, looking for a discrete indoor IP camera (1080p+) that is Synology compatible and be able to sit on a desk. A lot of the ones I can see are big bulky ceiling mounted.
They have 5 megapixel versions available now.
My mate just got 4 cameras and a nvr installed for £800 off Facebook.
Why do you need an indoor camera?
I'd look into nest indoor IQ cameras personally for the smart benefits.
It's not going outdoors. Not into the Nest thing, I'd like to setup multiple cameras around the house which is better with Synology. I found the Amcrest UltraHD 2K which seems reasonable.
