Thanks.I think about £160 each, but I put a 256GB card in each as a backup, which was about another £40 each.
At 8MP/4k resolution and 16Mbps constant bitrate I think 256GB only gets you about 24 hours of footage.
Custom built PC to act as a Blue Iris server is the NVR. (8700k, 16GB Ram, 18TB HDD)
Cam purchased from dvs.co.uk. I had to create a trade account though, don't think they sell to non-trade. I think they're all sold out of the new 8MP ColorVu ones at the moment anyway.
Before that I got some form cctvdirectonline.co.uk though. They were a tad more expensive, but not much, and anyone can order with a normal account. Looks like they have stock at the moment.
Good PIR, anyone have a link ? British weather seems to defeat many of them in short order
Just been told to sort CCTV for my parents bungalow next week, it’s a rural location with no street lights/light pollution, gated drive access to front and rear. Initial idea is 4 external cameras to cover front door, rear door/gate and the side where the oil tank is, the final camera to cover the front gate. No need for PZT and only basic processing of target areas (very little post/no visitors), and my preference is PoE rather than coax. I’ll need a minimum of 4 chan PoE NVR (8 would be better) to do the processing and push notifications to two iOS devices. Three turret cameras and possibly a bullet cam pointing square on down the drive to get number plate etc. Obvious contenders are Dahua or Hikvision, ColorVu was my first thought as I remember being impressed seeing the first gen stuff, image quality is more important than resolution. Anyone care to point me in the right direction?
Ideally I would go BI, but it’s an 800 mile trip to do anything to this set-up, so I need fire and forget.
I have absolutely no interest in having a screen inside, the only thing i want it to do is immediately ring (via app) both my phone and my fiancée's phone if someone presses the button, and to be able to open the gate from the app whilst on the call.
1) I see lots of people discussing SIP servers etc. I assume for this set-up I don't need this at all and I can just use the DMSS p2p functionality etc?
2) Will the camera be able to be connected to the NVR and work in the same way as my other cameras, recording on schedules/motion detection etc giving alerts even if someone doesn't press it?
have you considered one of the "doorbells" / entry systems that tie into the dahua/hikvision systems to give you camera coverage there and control gates too?
Do you want it to call/text you or send you a DMSS alert? If you want the former then you need SIP for the latter the P2P will work. SIP will be faster and more reliable.
The camera will record to the NVR-5208 but you will need to do the motion detection on the recorder whereas the TiOCs can also do it on the camera.
Both those doorbells will trigger a relay so yes, you can open a gate.
Do bear in mind that the image quality from those doorbells is awful. I seem to recall suggesting a pair of cameras to cover your gate - a TiOC for area view and illumination and a zoom to get a good image of who/what was at your gate.
The main issue with the HiLook is going to be the 12.5fps at 5MP vs 30fps at 4MP on the Hikvision. The other major difference is that the Hikvision camera has all the AI built into the camera whereas the HiLook cameras need that functionality in the NVR. Which is OK because the NVR108 has some AI functionality but not as good as the Hikvision models. So yes, it’s double the money for the cameras but the images will be smoother and you will get fewer false alerts.
Hikvision also gives you their app vs. HiLook’s app which is slightly nicer. If it’s a financial decision then the HiLook is a no-brainer but if you can stretch to the Hikvision cameras then I would. On the NVR front it’s much harder to justify the extra £70-ish for the Hikvision recorder over the HiLook, but if yiu can stretch to it it’s a slightly better specified unit but the better spec may not be anything you need - it will record at 4K on all 8 channels whereas the HiLook will only record 1 channel at 4K and if you use that, it will only record at 1080P on the other channels. It’s little things like that that may or may not be important to you/your parents. The Hikvision recorder gives you scope to upgrade whereas the HiLook is good enough for what you want to do today. I’ve not actually used the HiLook, but I can’t believe it won’t work with Hikvision cameras and the Hikvision will work with almost any IP camera.
Appreciate the reply
The last time I went down to do some work (replace a door and some windows with UPVC equivalents) I ended up having to re-roof the extension, not sure how happy they’ll be to see me if I drop nye on a grand on CCTV/security lightingJoking aside this will be the first of several, it’s less about what it will cost than it is about getting it right and not having to drive down/back again. This is literally the worst property to start with as it's 400 miles away, but it is what it is.
From what you’ve pointed out, a Hikvision NVR seems a decent shout - main brand app support, full resolution recording on all cameras, even ignoring the frame rte issue as I was expecting to reduce to 50% anyway to save on space. If I had longer, i'd order in a selection of cameras to play with and see how I got on, time is against me though. Time to get shopping![]()
