Man of Honour
- 11 Dec 2002
- Darkest Norfolk
Crimping is a bit fiddly, but get a load of cheap connectors, watch a few videos and practice - make sure you get a cable tester and you can check how you cable is doing. Its actually worth getting decent cable ends for when you do the install properly as the cheap ones can break/fail later down the line.
I've tried pulling made up cables before - the trick is to tie a guide line on it and then encase the connector in electrical tape before you try and get it through a cavity.
