Hi guys,
I'm looking to fit CCTV to my house. In my mum's I fitted pretty inexpensive Amazon specials, using PoE and into BlueIris.
It's been almost 10 years and I'm still super happy with that setup although I expect tech has moved on and it can only be better now
I have a home server running 24x7 - what cams would you recommend? Really don't want to break the bank.
I stick to Hikvision and Dahua but the key thing for overall picture quality especially at night it sensor size, see my post here:
Spec me a CCTV System
Hi all. Seems like everyone has a great depth of CCTV knowledge on this thread so I thought why not ask you guys. I have three Reolink RLC-810A cameras sitting and waiting to be installed at my new home. I want to put two facing the front and one facing the garden. I would like to use the...
Don't be overly keen to go for 4K (8MP) unless sensor size compensates for this and you really need that extra definition despite the extra storage and processing overhead. Similarly colour night vision while a real eye candy feature is good only if you've got some background lighting at all times when dark (for example streetlights where I live shut down 1am to 4am) or you're happy with the integrated white lights being on or get one that also has IR illumination. Also colour night cameras often only have sharp focus from 3 or 4 metres away (and worse on narrower angle lenses) from the camera which can be important for some areas.
