Looking for advice after a failure today.
I bought a Lorex system from Costco around 3 years ago and it has worked great up until now. The NVR stopped working today and after some investigation it looks like a resistor near the fan header on the board has went pop. There are 7x 8MP 15fps cameras attached to it. My understanding is that the Lorex kit is rebranded Dahua. 6 of the 7 cameras have audio and ‘active deterrent‘ which is a small light and the ability to alarm. I don’t use the active deterrent feature but the audio recording ability has come in handy.
I have a couple of options.
1. Buy a new NVR.
2. Repurpose a spare PC as an NVR.
Option 1, buying a new NVR, I‘m guessing it would be best to go for a Dahua branded model that supports 8 channels at 4K. Are there any particular models which will or will not work better? Would a new NVR support all of the features on the cameras? From what I can see, the cost of this would be £150-300.
Option 2, I have a Dell Optiplex 3060 sitting here unused. It has an i5-8500, 8GB, 256Gb NVMe and I can add the WD Purple 2Tb from the Lorex NVR. Would this spec support the requirements? Would Blue Iris be the best software? Cost of software and an 8 port PoE switch would be about £180-ish.
Thanks.
1. Buy a new NVR.
Thanks.
