Deleted member 66701
D
No takers at CPF marketplace then for your P-Rocket?
I had two, I'v sold one and modded the other with a better regulated 2A single mode driver.
Half my family want torches for christmas now, after having a bulb go and using my TK12 shining at the white ceiling as a temp light. They were amazed that a tiny led can light a whole room up .
Don't think they will be getting a Fenix though, too expensive. I'll have to do a bit of research for a decent cheap torch.
The ITP Lights are hard to beat in terms of performance per pound spent.
A[L]C;17513707 said:
A[L]C;17555006 said:anyone?
No. Steer well clear of LED lenser torches.
If you can't stretch to the £45/£50 uk price of a Fenix or 4sevens Quark (which I'd highly recommend) then this would make a fine light, head and shoulders above the LED Lenser:-
http://www.flashaholics.co.uk/itp/itp-sa1-eluma.html
http://www.flashaholics.co.uk/itp/itp-sa2-eluma.html
I've linked the single AA and double AA verions as you didn't say what size you preferred.
Both a shade over dalin80's budget at £32.95.
Reviews here:-
http://www.candlepowerforums.com/vb/showthread.php?t=266073
1 question though regarding terminology - is tailstanding for candle mode, which I woudl like to have and think the SA2 does?
Tail standing is the ability for the torch to stand on its end with the head of the torch pointing upwards. When inside a room it is very useful as it allows the light to bounce off from the ceiling and illuminate the room evenly.
Use code CPF at checkout
Im in the process of buying a MTE SF-15 SSC P7-D-SXO 4-Mode Memory 900-Lumen LED Flashlight (1*18650) Its only made in China but has MANY 9/10 reviews from around the world from indipendant reviwers. It doesnt use AA bats tho only 18650 (best to get rechargables) It has 900 Lumens (but a lot of reviwers say its more like 400-500) Im using it for early morning bike rides my self
Also.. it has a low price tag at £24. Ive pretty sure its been featured on the gadget show too! (not 100% sure about that tho )
