Depends on the flashlight you want to use them with as some take different size cells.
Eh? 26650 IS the size of the cell - one 26650 battery is the same size as any other 26650 battery!
As in the length of the battery itself.
The keeppower 26650 is shorter than the olight 26650 and thinner.
For the ThruNite TC20.Depends on the flashlight you want to use them with as some take different size cells.
Budget?Torch experts, I need a recommendation! I appreciate the ideal torch probably lies within these 240 pages, but I've not got the time to read everything (he says at 1:25am surfing OCUK.....).
My current torch is a cheapy LED jobby from Halfrauds. It's "2x AA" in size.
Requirements:
Google search brings back the "JETBEAM JET-I MK CREE XP-G". Looks good, any experience?
- Compact and lightweight. I don't mind if it's long and thin or short and fat
eek
but so long as the overall volume is relatively low.
- Bright! Brighter the better.
- It's needed for more spotlight type work than a wide spread of light. If it can adjust between the two is a bonus but not essential.
- Battery or chargeable, doesn't matter.
- Well built (can handle drops etc, so no cheap plastic)
- Price is flexible, I don't want to go crazy but I'm fed up with cheap crap torches.
- Did I say bright? Stellar levels of brightness!
Let me know what's out there
Thanks
Budget?
They shouldn't be different. The 2665 bit in the battery name means it's 26mm wide and 65mm long. Same with an 18650 battery - 18mm wide, 65mm long.
Not worried, ideally not crazy, perhaps up to £40-50 but ideally less
Can you tell more about the intended usage. What range do you need? Would a head torch be more use?Torch experts, I need a recommendation! I appreciate the ideal torch probably lies within these 240 pages, but I've not got the time to read everything (he says at 1:25am surfing OCUK.....).
Requirements:
- Compact and lightweight. I don't mind if it's long and thin or short and fat (
) but so long as the overall volume is relatively low.
Thanks
The Jetbeam I mentioned could be an option,and you could get a Nitecore charger and a couple of Sanyo 3500mah 18650 cells for your budget.
