Spec me an LED Torch
Is it ok if I use the 'L' word in this thread? Lantern?
I've got a few torches from the likes of Olight, Fenix and Nitecore but what I could do with is a lantern type providing excellent battery life and good 360deg light.
Does anyone have recommendations please?
I’m also looking for a lantern.
Any recommendations for a decent, single 18650 light? that isn't too expensive?
I'm probably going to get a MR70 for when I need more light, but my current light uses an 18650, but needs replacing (dodgy tail switch, and the emitter doesn't change modes anymore), so it would be nice if I could make use of the battery without it costing too much.
I’ve seen Fenix do a rechargeable lantern, other than that there are some cheaper camping style one’s.
I’ve found a diffuser in the box for my Olight SR51 which fits over the front and provides a good spread of light so I don’t think I will bother with a lantern type now.
Just a heads up, looks like Olight no longer have RMA support in the UK so items would need to be posted back to China.
They did have a firm called Deben in the UK but looks like they no longer handle RMA for Olight.
What are your requirements?
  • Budget?
  • Most common purpose/range/duration of use?
  • Any other requirements - Tail switch again? Modes?
I rate my Jetbeam IIM...
I thought I'd post a heads up /micro review of the Jetbeam IIM I got for £19 delivered before Christmas. I've just had a look and it looks like you can get it for £22 right now.
This is a fairly common form factor - single 18650 cell light.
I bought it as a spare to have around the house, because, for £19, it seemed a good deal.
Having received the light, and used it, I'd change that assessment, and say it's an excellent deal.
Output seems as advertised, build quality is what I expected from Jetbeam (ie, on a par with Fenix and Nitecore), but, for me, the surprise was the functionality...
This has a tail button switch, and a flexible rotating locking mechanism that allows you to lock it on, off, and a few other things.
The light is protected, and single cell, so I'm happy using 3500mAh Sanyo cells for £6 a pop.
All in all, I'd say this adds up to a very good value set up that will exceed the requirements of most users.
Hope that's of use to someone.
This is my final torch collection, not buying anymore!
Left to right
Olight R50
Nitecore TM11
Olight SR51
Fenix TK75
Thrunite TN12
  • Budget?
Budget is around £20, use is general use, small enough to leave in my pocket for when I'm out in the dark etc, need to check the back of a cupboard at home etc.
I've just looked up the Jetbeam IIM, It's currently £20.56, and looks like it pretty much perfectly matches my needs, so I might have to grab one :)
My Rofis MR70 turned up today, for those that bought one and are looking for a spare battery my keeppower 26650's work fine (5200 & 6000 mAh).
Really like the sidelight on this.
Looking for a recommendation. After something that takes two 18650s (already have) and can have a super powerful focused beam. I had a similar one years ago but unfortunately i lost it. Looking to spend a bare minimum that gets me something silly powerful.
