This thread is pretty big, so if someone has already asked about a torch that fits the following I apologise! Any recommendations? Thanks in advance
1) How would you prefer to purchase the light?
Online, UK retailer preferred.
2) Budget: An easy question, but you may change your mind after answering the rest!
£50-£70
3) Format:
I want a flashlight.
4) Flashlight-specific format/size:
Every day carry small (2-4 inches).
Every day carry medium (4-7 inches).
5) Emitter/Light source:
LED (known for efficiency, longevity, and compactness)
6) Manufacturer:
I want to buy a light from a traditional mass producing manufacturer that is ready to go out of the box.
7) What battery type do you want to use?
I intend to use alkaline batteries (AAA, AA, C, D) (disclaimer, while it does not preclude all choices, these are not recommended for many of today’s most powerful lights)
I intend to use rechargeable nickel chemistry (NiCad, NiMH, NiZn)
I intend to use lithium primary batteries (CR123, CR2, Energizer Advanced/Ultimate Lithium AA/AAA)
I intend to use rechargeable lithium (li-ion) chemistry. Feel free to specify a size if you know which size you want (14500, RCR123/16340, 17500, 17670, 18650, etc.)
If the torch fits the right criteria I’m happy to get the right batteries for it. Already have a NiCad, NiMH charger but buying a different charger wouldn't be an issue.
8) How much genuine out the front (OTF) light do you want/need? Sometimes you can have too much light (trying to read up close up with a 100 lumen light is impossible).
I want to walk around an unlit rural area (50-150 lumens).
I want to illuminate my entire backyard or a campsite (150-300 lumens).
9) Throw vs. Flood: At what distance will you be most likely to use this light? Select all that apply.
5-20 yards/meters (check out a noise in the backyard)
30-50 yards/meters (I have a big backyard)
10) Runtime: Not over-inflated manufacturer runtime claims, but usable brightness measured from first activation to 50% with new batteries (Measured on maximum output).
90-120 minutes (Runtime is moderately important, but still not critical)
3 hours + (I critically need this light to run on max for extended periods in between battery changes/charges).
11) Durability/Usage: Generally the old phrase “you get what you pay for” is very accurate for flashlights.
Slightly Important (Walks around the neighborhood).
Very Important (Camping, Backpacking, Car Glove-box).
12) Switch Type and location (choose all that apply):
I don't care.
13) User Interface (UI) and mode selection. Select all that apply.
A simple on-off with only one output level is fine for me.
14)Material/Finish/Coating
I don’t care.
15) Special Needs/extras: Is there anything else you want or need that hasn't been mentioned? Select any below.
N/A
