Cancel the order? email them and ask to change it?
They're in the US so they'll be both helpful and efficient.
Bah! Laziness
Any battery that comes out of the pack > 3.7v, put it on charge (supervised) and any that charge to >4.1 and don't get hot doing so, set aside. Any that are already <3.7v, get hot or don't get to 4.1v - bin them (well recycle them actually).
The ones that seem ok, store them in a normal room temp environment for 24 hrs and test the voltage again - any that show less that a 0.05v drop after 24hrs are good and keep them - if any sag by more than 0.05v bin them (e.g. 4.11v then 4.05v after 24hrs = bin).
Oh, and don't blow yourself yup when dismatling the pack!
Not really - there are tons of other torches I'd have at that price (£35ish) over an LED Lenser.
Can anyone recommend a very cheap multimeter? Seems like it would be a good idea to get one but I'd like to spend as little as possible as i wouldn't use it for anything else.
Those look like the ones I have!
Damn you guys, I don't have any need for a torch but you just make me want one.
Just ordered that ShiningBeam S-mini and the charger that was recommended, just need some 18650 cells now. No idea which to go for.
Did you get the XM-L version and if so what is the run time on high?
