Spec Me
Permabanned
2 Apr 2013
North West
Ok guys I did post a spec me the other day but my budget is now a lot more. I have £3500 to spend on a full system. I know skylake is around the corner but thats ok. I want a Fury X and obviously theres no price yet so I will say £600 for that. So basically £2900 for the rest including monitor, keyboard and mouse too. I want a big case, the one I have now on my other system Antec 1200 is massive but anything bigger?. This is for gaming and need a decent amount of ddr4 ram too. Was looking at X99 but not sure what to pick. I can probably up my budget to £3800. Thanks for the help.
I quite like the look of these https://www.overclockers.co.uk/showproduct.php?prodid=MY-184-GL any good?
YOUR BASKET
1 x Intel 5960X Extreme 3.00GHz (Haswell-E) Socket LGA2011-V3 Processor - Retail (BX80648I75960X) £799.99
1 x Samsung U28E850R 4k 28" FREESYNC Gaming Widescreen LED Monitor - Black £499.99
1 x Intel 750 Series 400GB PCIe 3.0 X4 HHHL Adaptor NVMe Solid State Drive (SSDPEDMW400G4ES) £319.99
1 x Gigabyte X99 SOC Champion Intel X99 (Socket 2011) DDR4 ATX Motherboard £204.95
1 x Phanteks Enthoo Primo Full Tower - Black/Orange £199.99
1 x Kingston Predator 16GB (4x4GB) DDR4 PC4-21300C13 2666MHz Quad Channel Kit - Black (HX426C13PB2K4/16) £179.99
1 x EVGA SuperNova 1000W '80 Plus Platinum' Modular Power Supply (220-P2-1000-XR) £161.99
1 x Corsair Gaming STRAFE Mechanical Gaming Keyboard – Cherry MX Red (CH-9000088-UK) £99.95
1 x Corsair Hydro H110i GT 280mm Extreme Performance Liquid CPU Cooler (CW-9060019-WW) £99.95
1 x Western Digital Caviar Red 2TB SATA 6Gb/s 64MB Cache WD20EFRX - OEM HDD £70.79
1 x CableMod E-Series G2 & P2 Cable Kit - Black / Orange £69.95
1 x Zowie FK1 High Performance Gaming Mouse £49.99
Total : £2,784.16 (includes shipping : £22.20 Ex.VAT).
Best X99 board (just see all thee world records at HWbot).
Huge case for the CPU cooler and FuryX AIO cooler.
£72 cashback for CPU+Board and a further £32 cashback because of the Intel750 - https://toptechcashback.com/uk/en/pages/cpumb/qualifying
YOUR BASKET
1 x Gigabyte X99-Gaming 5P Intel X99 (Socket 2011) DDR4 ATX Motherboard £229.99
1 x Phanteks Enthoo Primo Full Tower - Black/Red £199.99
1 x GeIL Super Luce 16GB (4x4GB) DDR4 PC4-24000C16 3000MHz Quad Channel Kit - Red (GLR416GB3000C16QC) £179.99
1 x CableMod E-Series G2 & P2 Cable Kit - Black / Red £69.95
Total : £2,809.20 (includes shipping : £22.20 Ex.VAT).
Red+black.
The cases you want are 900D or Enthoo Primo really - well suited to custom loop cooling
Will you be fully watercooling this? Might be worth doing at this budget
Sorry only just seen this question, I have never done a full custom loop before but yes im very interested in giving it a go. My budget should be plenty going off the specs so I might do just that. I know theres 2 versions of the Furyx coming, I was wanting the watercooled one. Will that be like an all in one kind of thing or will it need a custom loop?
Also if I do need a custom loop what kit would I need? and again price isn't that important. I have had a good look at those cases but not made my mind up yet. Might go for the 900D. Would that be ok to fit in a H100i + a fury X.
It will be a sealed water cooler similar to the R9 295X2.
http://wccftech.com/amd-radeon-r9-fury-teardown-pcb-liquid-cooling-pump-block-pictured/
If you are going for a H100i for the cpu cooler, then you don't need a 900D.
900D is old now, That Phanteks probably has it beat on price/features.
OcUK have water cooling kits that can be expanded upon over time but saying that a 240mm/280mm AIO like a corsair H110i etc will cope for most reasonable uses and overclocking.
So the Fury X is doesn't need a loop, thanks I was unsure. I really like the Phanteks and would like a go at a full loop, its just I have no knowledge at doing them. Have been building computers for years but never actually done that. So if I got the H110i the Phanteks would be suitable then? I think I will go with that and trust your opinions. How on earth do you post the items above in a list with the pictures and links? is there some kind of extention I need for chrome?
Even the cheaper Phanteks luxe or Enthoo Evolve ATX will take a 240/280mm AIO for the CPU in the roof and a spot on the rear for the FuryXs 120mm rad.
These cases will fit it all,
YOUR BASKET
1 x Corsair Graphite 780T Full Tower Case - Black (CC-9011063-WW) £151.99
1 x Corsair Graphite 760T Windowed Full Tower Gaming Case - Black (CC-9011044-WW) £151.99
1 x Phanteks Enthoo Evolv ATX Mid Tower Case - Black £139.99
1 x Phanteks Enthoo Luxe Full Tower Case - Black £119.99
1 x Corsair Graphite 730T Full Tower Chassis - Black (CC-9011046-WW) £84.95
Total : £688.39 (includes shipping : £32.90 Ex.VAT).
Thanks Stulid, I am going to go with the Ethoo definately. How do I list my items like you just did? Yes I know im thick lol . When are you adding the fury x onto the site so I can add it to cart ? eagerbeaver me !
I have never built a custom loop so I can't help you on that part. If you just want something you can fit and forget about, then you would be better with a sealed unit such as the H110i GT or H105 etc.
What are you using this pc for as I don't think you mentioned that ? Hopefully more than gaming if you are going with the 5960X :cool:
Ok.
Ditch the sound card and use the motherboards onboard sound, reason being,
• GIGABYTE AMP-UP Audio™ Technology
• GIGABYTE Direct Audio Route Design
• Independent Right and Left Audio Channel PCB Layers
• Creative® Sound Core3D™ Quad-Core Audio Processor
• Creative SBX Pro Studio Audio Suite
• Nichicon high end audio capacitors
• Gold Plated Audio Hardware
• Quad DAC-UP USB Ports
Basically its got sound card quality parts on it.
