- 5 Feb 2009
It's what I've kept saying - it sounds to me like what you want is an interface with headphone out and low/zero latency source playback for monitoring, as well as for overdubbing i.e layering recordings.
For the channels you might need to check the manual to see whether that device will pass separate audio streams simultaneously to the DAW software. If it can, then you either 1) just need to set up the software to handle things better or 2) need to install the manufacturer's ASIO drivers and then set up the software.
Sorry, but I think the problem is that a good chunk of all this is completely over my head!
Is there a way you can explain this very simply to someone who's never plugged an electric instrument into anything before this?
Edit: also see here for audacity specific guidance: https://manual.audacityteam.org/man/multi_channel_recording.html
and make sure you have got a version of audacity that can use ASIO drivers. it sounds a bit complicated. I think it was this that drove me to ditch it and just pay for cubase in the end. It was a while ago now.
https://manual.audacityteam.org/man/asio_audio_interface.html
Thanks, I didn't know the version of Audacity would make a difference. I will check which version I installed on my son's PC tomorrow evening.
