No problem. Someone in the tread mentioned the film the other day which I had not thought about either. My kitchen patio and window both have blinds too (aluminium intu blinds) which I use to block out the sun and you can feel a difference but it does still let a lot of heat in.
I often have my blinds shut all day in the summer which is not ideal. If the film means I can have the blinds open more and reject much more heat I will be quids in with the running costs of the AC. I have 2x 2.5kw units in the 2 bedrooms above the kitchen and these are way over spec'd for the rooms (2.5 x 3.9m and 2.2 x 2.8m). Quite often I just run them with the rooms doors open and it helps keep the rest of the house cool (apart from the kitchen). I do the same with my third 2.5kw unit in my master bedroom on the floor above.
