THE NOISE from the condensation pump is driving me crazy.
Here is the sound mine makes. Wakes me up and sounds like I have a toilet in my bedroom.
https://www.dropbox.com/s/p3uwisj3s6mhyin/Condensation Pump with bubbling.m4a?dl=0
The engineer is coming on Monday. I spoke to the boss today who said that all pumps were noisy but that they could move it to the guest bedroom room. I said that was great but what about when I had a guest over.
Basically it's fairly intolerable with three of these suckers happening all the time. He said it can be alleviated by having a larger reservoir so it doesn't go as often but I don't think that's going to help.
I suspect it might be *hard* to use gravity but not impossible and they might just be reticent to put in the work.
Either that or perhaps there's a pump that's silent.
IT LITERALLY JUST HAPPENED AGAIN IN MY LIVING ROOM
it's not just me then.I mean that is absolutely ridiculous.
I agree, That would be fine in a noisy environment but not in the home.
There are plenty of other pumps which are much quieter and can be mounted away from the unit.
How far away and must they be mounted lower than the unit? Presume so?
The one in the link below can be mounted up to 2 metres away.
https://www.bluediamondpump.co.uk/microblue
but just to be clear since it's going by gravity to the pump I'm assuming that two metres must be on a slope. I suppose it doesn't matter how gentle the slope. It's just that no matter where it is in my flat I'd hear it. And I have three of them. I want to get them outside!
I don't suppose you have a video or audio of one running? I can't seem to find anyone who can compare them for me. I'm hoping perhaps they could be run outside next to the machine and not inside near the AC units themselves. But in case they have to be it'd be good to know what has the lowest noise level. The blue diamond runs all the time; which is fine as long as it's fairly silent.
I guess the AC is mounted on an internal wall meaning evacuating the water straight outside isn’t an option?
Panasonic.What is the full system you had fitted?
