SSD advice and help
23 Nov 2009
North Leicestershire
Firstly can anyone see me having any problems with a SSD on my motherboard (gigabyte ga-790 fxta-ud5)
manual says the only 6gbps ports i have are
Marvell 9128 chip:
2 x SATA 6Gb/s connectors (GSATA3_6, GSATA3_7) supporting up to
2 SATA 6Gb/s devices
Support for SATA RAID 0 and RAID 1
The older Marvell controllers aren't great. You'll find they will give you slightly better sequential reads and writes than the AMD 3Gb/sec ports, but worse random reads and writes, and it won't be as reliable or consistent. That's assuming you're talking about an SSD with a 6Gb/sec controller, anyway.
So i'm pretty much ****** then SIGH , annoying upgrade itch is annoying
Just use the native AMD SATA 2 controllers. You'll still get a nice speed boost.
I find it wierd Marvell controllers on SSDs are amazing but Marvell controllers on boards to give SATA 6Gbps are terrible...
By using native controllers do you mean just install windows 7 and let it do it's thing. Sorry for sounding thick but i've never done anything regarding ssd's.
here is my MOBO btw
http://uk.gigabyte.com/products/product-page.aspx?pid=3258#sp
Yes, just use the normal blue ports. You can use either the Windows native drivers or the drivers from AMD, with AMD chipsets there's not that much difference in performance.
