RE your second pic, "volume_0000" is the only one showing as enabled/normal status/bootable/etc yet it shouldn't exist as its the left over space on the SSD but the RAID controller seems to be identifying it as part of a phantom stripe (RAID 0) array.
Is it possible to delete the RAID volume "volume_0000" without deleting the volumes "volume_0001" (the cache volume) or "RAID0" (the actual stripe) as that may be what's confusing the controller.
Any idea if you have the latest firmware for the SSD?
Didn't notice the last post, not sure what to suggest to that, you could try temporarily booting your system without the over clock as that can sometimes cause issues with software RAID, if you put the cache drive back in and have it as a normal disk instead of part of the array you could install Windows on that and then the Intel software which would presumably be able to error check the array.
